[GRASS5] d.zoom patch?
Radim Blazek blazek at itc.it
Thu Oct 2 04:02:34 EDT 2003
On Wednesday 01 October 2003 18:51, you wrote:
> Hi,
> I ran into a small problem with d.zoom in grass 5.7. There is an
> uninitialized variable (smap) that causes a seg fault in main.c. I
> just got rid of the variable and its references entirely---don't know
> if that's the right thing to do, but it seems OK to me, and it has
> fixed the problem. I've attached the (trivial) patch, if only so that
> those in the know can see where the problem lies.
Thanks, I forgot to remove it when I changed sites library.
Radim
