[GRASS5] Licensing problem
Bernhard Reiter bernhard at intevation.de
Tue Oct 7 19:41:15 EDT 2003
On Thu, Sep 25, 2003 at 05:45:31PM +0200, Bernhard Reiter wrote:
> > > We need to:
> > > 	a) replace ./src/include/color.h
> > Method 3:
> > Delete src/include/color.h and replace its sole use in
> > src/ps.map/ps.map/cmd/vector.h with a local definition for the only
> > portion which is actually used:
> > 	typedef	struct {
> > 		unsigned short r, g, b;
> > 	} RGB;
> Sound good to me if "color.h" is not included somewhere else.
> Can you make the change Method 3 then?
I've done the change for releasebranch_26_april_2002_5_0_0 now.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031008/8e9391ed/attachment.bin
