[GRASS5] [bug #2155] (grass) integrating GRASS r.mapcalc with MPI
Request Tracker grass-bugs at intevation.de
Tue Oct 14 00:07:52 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2155
Subject: integrating GRASS r.mapcalc with MPI
hi,
i was wondering... can i try to apply the MPI (message passing interface) in
grass.. i download the sample r.mapcalc from a gRASS website and i just
did some simple work as it takes a map and reproduce a thoroughly same
map as an output. i was thinking whether it is possible that i run that on a
beowulf cluster. but as i think further, i dunno how am i suppose to run the
program in the end. coz the grass need to be sort of compiled with gmake5
while the mpi needs to be run as mpirun -v filename.
-------------------------------------------- Managed by Request Tracker
