[GRASS5] [bug #2173] (grass) Compiling under Mandrake 9.1
Laura Toma ltoma at bowdoin.edu
Tue Oct 21 13:22:57 EDT 2003
As far as I can tell all the compile problems with r.terraflow are
because of the #include lines.
With gcc3.2 and 3.3 all  #include <X.h> should be replaced with #include
<X>.
Also, the header strstream.h is deprecated, and should be replaced with
sstream.
With 3.2 these problems can be postponed with the compile flag
-Wno-deprecated. Not sure about 3.3. I will try to install 3.3 and
 compile it.
In any case the code should be fixed to compile without warnings (and
errors).. I'll  be working on it.
-Laura
Thierry Laronde wrote:
>On Mon, Oct 20, 2003 at 11:18:25PM +0200, Request Tracker wrote:
>>this bug's URL: http://intevation.de/rt/webrt?serial_num=2173
>>Subject: Compiling under Mandrake 9.1
>>To compile the source, had to change Line #48 in minmaxheap.h from #include <strstream.h> to #include <strstream>.
>These are the preliminary problems with all the C++ code and the new
>GCC 3.x...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20031021/0c3dc4e7/attachment.html
