[GRASS5] Tcl8.4 support?
Sun Sep 14 07:14:59 EDT 2003
Two steps forward, another back. A couple of mistakes by me & bugs
getting mixed up here .. and still no joy.
Turns out the raster I was testing NVIZ out with is a CELL map.
Tried to run nviz on an integer based raster on a RedHat install & it
gave the same SegFault.
So NVIZ doesn't like integer based maps.
It also fails with pages of errors if there is no data in the
current region (d.zoom to an all null part of the map).
If these will always fail, checks early on & a graceful exit with
useful error messages would be better..
So that explains the SegFault anyway.
But back to Debian with TclTk 8.4 and the bug as reported in
http://article.gmane.org/gmane.comp.gis.grass.devel/1883
"it does freeze up (0% cpu) at the first instance of "exec"
in etc/nviz2.2/scripts/nviz2.2_script, line 78:   (Adding panels section)
    set panels [exec cat $index]
(I tried placing some exec's further up in the script & they did the
same lock-up)"
sample run:
GRASS:~ > nviz raster_dem
The papers are available at
http://www2.gis.uiuc.edu:2280/modviz/
Loading Data
Loading Data
translating colors from fp
Adding panels from /usr/src/grass5source/grass-5.0.3rc3/dist.i686-pc-linux-gnu/etc/nviz2.2/scripts
and then it just sits there using 0% cpu with the "Please Wait.." window up.
strace -f ends with looping getppid() every 2 seconds or so:
Process 7403 detached
[pid  7402] close(14)                   = 0
[pid  7402] read(13,  <unfinished ...>
[pid  7397] <... poll resumed> [{fd=3, events=POLLIN}], 1, 2000) = 0
[pid  7397] getppid()                   = 7396
[pid  7397] poll([{fd=3, events=POLLIN}], 1, 2000) = 0
[etc...]
until I kill it.
full log here:
  http://bambi.otago.ac.nz/hamish/grass/strace-f_nviz.log.gz
Running gdb, then ^Z when it gets stuck:
GRASS:./grass-5.0.3rc3 > gdb dist.i686-pc-linux-gnu/etc/nviz2.2/NVWISH2.2 GNU gdb 5.3-debian
Copyright 2002 Free Software Foundation, Inc.
(gdb) run -f dist.i686-pc-linux-gnu/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ
Enter the name of an existing Raster file
Enter 'list' for a list of existing Raster files
Hit RETURN to cancel request
> raster_dem
Loading Data
Loading Data
[<wait> Ctrl-Z]
(no debugging symbols found)...(no debugging symbols found)...
Program received signal SIGTSTP, Stopped (user).
[Switching to Thread 16384 (LWP 7482)]
0x4049ba54 in read () from /lib/libc.so.6
(gdb) bt
#0  0x4049ba54 in read () from /lib/libc.so.6
#1  0x401b3004 in _LIB_VERSION () from /usr/lib/libtcl8.4.so.0
#2  0x4018193f in TclCreatePipeline () from /usr/lib/libtcl8.4.so.0
#3  0x40182195 in Tcl_OpenCommandChannel () from /usr/lib/libtcl8.4.so.0
#4  0x4016ee7a in Tcl_ExecObjCmd () from /usr/lib/libtcl8.4.so.0
#5  0x40136646 in TclEvalObjvInternal () from /usr/lib/libtcl8.4.so.0
#6  0x401594a2 in TclCompEvalObj () from /usr/lib/libtcl8.4.so.0
#7  0x40158adc in TclCompEvalObj () from /usr/lib/libtcl8.4.so.0
#8  0x4013764d in Tcl_EvalObjEx () from /usr/lib/libtcl8.4.so.0
#9  0x4013ce8c in Tcl_ForeachObjCmd () from /usr/lib/libtcl8.4.so.0
#10 0x40136646 in TclEvalObjvInternal () from /usr/lib/libtcl8.4.so.0
#11 0x4013707c in Tcl_EvalEx () from /usr/lib/libtcl8.4.so.0
#12 0x40171aa6 in Tcl_FSEvalFile () from /usr/lib/libtcl8.4.so.0
#13 0x40170c2a in Tcl_EvalFile () from /usr/lib/libtcl8.4.so.0
#14 0x400824a9 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
#15 0x080573bc in strcpy ()
#16 0x403f9a51 in __libc_start_main () from /lib/libc.so.6
(gdb) info f
Stack level 0, frame at 0xbfffea98:
 eip = 0x4049ba54 in read; saved eip 0x4018193f
 (FRAMELESS), called by frame at 0xbfffea98
 Arglist at 0xbfffea98, args:
 Locals at 0xbfffea98, Previous frame's sp in esp
 Saved registers:
  ebp at 0xbfffea98, eip at 0xbfffea9c
(gdb) l
No symbol table is loaded.  Use the "file" command.
(gdb) info args
No symbol table info available.
(gdb) info locals
(gdb) quit
A debugging session is active.
Do you still want to close the debugger?(y or n) y
GRASS:/usr/src/grass5source/grass-5.0.3rc3 >
I'll (re)confirm Tcl/Tk 8.3 doesn't show this behavior tomorrow.
still confused, but slightly less so,
Hamish
old business:
> > > AFAICT from the error message, it's the core NVIZ process which
> > > crashed; i.e. not the "nviz" script, but the NVWISH2.2 binary
> > > interpreting nviz2.2_script. To debug that, you would need to
> > > emulate the "nviz" script by setting up the various environment
> > > variables, then running NVWISH2.2 under gdb, e.g.:
> > > 	export GISDBASE=`g.gisenv get=GISDBASE`
> > > 	export LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
> > > 	export MAPSET=`g.gisenv get=MAPSET`
> > > 	gdb /usr/local/grass5/etc/nviz2.2/NVWISH2.2
> > > 	> run -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
> > > 	> -name NVIZ
> > I'm new to gdb, bear with me.
> >    -How to turn on debugging symbols?
> >    -How to set up symbol tables info? [(gdb) bt f]
> >       "No symbol table info available."
> Odd. Has the NVWISH2.2 binary been stripped?
Nope. At least not by me at the command line.
> > note NVIZ is printing "Version: @(#) 5.0.2 (April 2003)" before
> > the copyright notice..?
> That suggests that either configure hasn't been re-run since the last
> update, or NVIZ hasn't been re-built (forgot to run "make distclean"
> first), or that NVIZ failed to compile and the old version is still in
> place (forgot to "rm -rf /usr/local/grass5" before "make install").
That was a mistake on my part. I hadn't installed with 'make install', I
was running GRASS from bin.i686-pc-linux-gnu/grass5. I then told gdb to
run NVIZ from /usr/local/grass5, which was 5.0.2.. A 'make uninstall'
later and a fresh compile of 5.0.3rc3 directly from the tarball gives
the same SegFault & gdb session though [turns out that was the CELL map].
Where do you change the Makefiles to have GRASS compile with "gcc-2.95"
instead of"gcc" (ie gcc-3.3) ?
> > Program received signal SIGSEGV, Segmentation fault.
> > [Switching to Thread 16384 (LWP 5725)]
> > 0x4042452d in vfprintf () from /lib/libc.so.6
> > (gdb)  bt
> > #0  0x4042452d in vfprintf () from /lib/libc.so.6
> > #1  0x4043d386 in vsprintf () from /lib/libc.so.6
> > #2  0x4042c21a in sprintf () from /lib/libc.so.6
> > #3  0x0808edd1 in strcpy ()
> > #4  0x0805c2f8 in strcpy ()
> > #5  0x08052424 in strcpy ()
> > #6  0x080506a1 in strcpy ()
> > #7  0x401357ff in TclInvokeStringCommand () from
> > /usr/lib/libtcl8.4.so.0#8  0x40136646 in TclEvalObjvInternal () from
> > /usr/lib/libtcl8.4.so.0#9  0x4013707c in Tcl_EvalEx () from
> > /usr/lib/libtcl8.4.so.0#10 0x40137495 in Tcl_Eval () from
> > /usr/lib/libtcl8.4.so.0#11 0x401387d3 in Tcl_VarEvalVA () from
> > /usr/lib/libtcl8.4.so.0#12 0x40138807 in Tcl_VarEval () from
> > /usr/lib/libtcl8.4.so.0#13 0x080536d7 in strcpy ()
> > #14 0x08053bc2 in strcpy ()
> > #15 0x0804c207 in strcpy ()
> > #16 0x40082452 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
> > #17 0x0805749c in strcpy ()
> > #18 0x403f6a51 in __libc_start_main () from /lib/libc.so.6
> If tcltkgrass is crashing inside "pure" Tcl/Tk code, you won't be able
> to find out much unless you have a version of libtcl which has debug
> info.
I think (could be wrong) Debian binaries are stripped by default.
