[GRASS5] Maximum number of categories
Mon Apr 26 20:35:17 EDT 2004
> [...] but if people have problems reading files you only have to
> tell them to make sure they are using 5.7.0 (rather than checking the
> date of the snapshot they used).
Is it possible to make g.version reference a macro of some sort to
return the build date? As it stands, "GRASS 5.3-cvs (2004)" and
"GRASS 5.7.-cvs (2004)" aren't very informative from a debugging point
of view.  ^
Even better than build date might be cvs checkout-date; the only way I
see how to do that is a cron job that touches and checks-in the VERSION
file with a $Date$ string in it, and then change the parsing on the
VERSION file. (or have the cron job update the file itself)
grass/src/CMD/VERSION
grass51/include/VERSION
Hamish
