[GRASS5] Re: [GRASSLIST:3781] minor update to tcltkgrass for GRASS 5.7
Sun Aug 1 02:53:16 EDT 2004
> > d.barscale's GUI isn't rendering properly. When you open
> > it, the bcolor= and at= descriptors are missing, and the following
> > error is displayed on the console:
> > extra characters after close-quote
> > bad window path name ".pw.f0.frame.optwin.fra.frame.lab1"
> > invalid command name "0,0"
> > bad window path name ".pw.f0.frame.optwin.fra.frame.lab3"
> > It is choking on the " character in bcolor=; if I change the module
> > to use ' instead, it works.. this will break d.text.freetype as
> > well.
> > Similarly, at= breaks when it sees [], that happens in d.text too.
> > It would be nice if the parser be a bit more robust to handle "[].
Ok, I think I fixed this one.
solution: in grass51/lib/gis/parser.c, replace
 ... -text \"$description\" ...
with
 ... -text {$description} ...
this text is in a sprintf() statement & the string goes into a command
which is eventually fed through:
echo "$command" | wish &
for the archives:
To debug the tcl code, I had to add a line to parser.c just before
system(cmd);
sprintf(stdout, "%s\n", cmd);
  [perhaps this should be a if(DEBUG=3) command?]
then run
GRASS:~> d.text.freetype > dtf_tcl.txt
then edit 'dtf_tcl.txt'  to remove the "| wish &" from the end.
then '. dtf_tcl.txt > dtf.tcl' to get rid of the echo-proofing chars.
then 'wish < dtf.tcl'  to test it.
It was easiest to fiddle with dtf.tcl until it was right and then go
back and fix parser.c to provide what was needed.
References:
"Is white space significant in Tcl"  http://wiki.tcl.tk/981
"Tcl quoting hell"  http://wiki.tcl.tk/1726
"1 minute intro to tcl"  http://www.pconline.com/~erc/tcl.htm
Next big bug is to get the Tcl menus to honour white spaces:
d.vect where="ident='foo' and location='bar'"
prints out to the stdout window with the double quotes when you click "Run",
but they get stripped before the command is run causing it to break.
Hamish
