[GRASS5] cuserid alternative?
William K woklist at charter.net
Sun Aug 1 19:05:11 EDT 2004
I checked the Mac OS X UNIX porting list archives and found a
suggestion to use getlogin() instead of cuserid (at least for the case
of passing a null pointer to cuserid).  Any thoughts?  I tried it by
changing dbmi_base/whoami.c to use that instead of cuserid - compiles
OK.
Is db_whoami() even used anywhere?  I didn't see it used in any of the
source.  Without it being used anywhere, I can't really say if
replacing cuserid() with getlogin() works (it's beyond my C knowledge
to say if it should work).
FYI, this is my new whoami.c (let me know if anything is wrong with it):
#include <unistd.h>
  \fn
  \brief
  \return
  \param
char *
db_whoami()
     char *getlogin();
     return getlogin();
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
