[GRASS5] 5.7: compilation error management - log file?
Markus Neteler neteler at itc.it
Fri Aug 6 07:40:22 EDT 2004
On Fri, Aug 06, 2004 at 11:43:17AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > Recently the 5.7 Makefile system was changed to continue
> > on compilation errors. While is is probably a good idea,
> In my case, it was essential; the build would get to lib/form, fail
> because I don't have Tcl/Tk 8.4 (Tcl_GetEncoding etc), and that was
> the end of the build process.
> > it's quite difficult to understand now which modules
> > were skipped.
> > Is there a way to implement a error log file support as it
> > exists for 5.3?
> Try changing this rule (in include/Make/Dir.make):
> subdirs:
> 	@list='$(SUBDIRS)'; \
> 	for subdir in $$list; do \
> 	    echo $$subdir ; \
> 	    $(MAKE) -C $$subdir; \
> 	done
> to:
> subdirs:
> 	    echo $$subdir ; \
> 	    $(MAKE) -C $$subdir || echo $(CURDIR)/$$subdir >> $(GRASS_HOME)/error.log ; \
> 	done
> You'll also need to delete/truncate error.log at the start of the
> build.
Thanks!
All implemented now in 5.7.
Markus
