[GRASS5] (Text based) startup screen patch
Markus Neteler neteler at itc.it
Tue Aug 10 06:16:29 EDT 2004
On Tue, Aug 10, 2004 at 11:13:13AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > Hi,
> > IMHO the line length of location/mapset in the text based startup
> > screen is too short.
> > I suggest attached patch to 5.3 (linked into 5.7):
> >  src/general/init/set_data.diff
> Actually, I've had the appended patch lying around for a while; it's
> essentially the same thing, only more so.
> > Any problems (it is still shorter than the  variable definition)?
> I don't think so.
Ok, submitted to CVS.
Markus
