[GRASS5] [bug #2580] (grass) config creates problem for make, won't bypass PROJ when it is not present... In short, make fails
Glynn Clements glynn.clements at virgin.net
Tue Aug 17 17:51:42 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2580
> Subject: config creates problem for make, won't bypass PROJ when it
The PROJ library is no longer an optional dependency. You have to have
PROJ 4.4.6 or later installed on your system in order to build GRASS.
As the standard PROJ distribution now does everything which GRASS
needs, there isn't any reason for GRASS to include its own copy of
this library.
> Also - compile information fails to include tree locations
> of any required "other" sources.
Can you elaborate?
Glynn Clements <glynn.clements at virgin.net>
