[GRASS5] r3.showdspf problems in GRASS 5.7
Helena hmitaso at unity.ncsu.edu
Thu Aug 26 11:26:22 EDT 2004
Michael,
I was away so I did not follow all discussion about r3.showdspf but my suggestion is that you
don't spend time on r3.showdspf and the cloud data sample - they are not good,
instead, please get GRASS5.3 or 5.7 from here - it has the volume visualization working
within nviz:
http://kopernik.cc.fmph.uniba.sk/~paudits/
The author is now working on extracting the new and modified parts of the code so that
it can be submitted to CVS, but you can use and test his GRASS5.7 or 5.3 code meanwhile.
Let me know if you need test data sets - the cloud data set supposedly does not work
with the current g3d.
Helena
Michael Barton wrote:
> I tried again to get r3.showdspf to work without success. I am using the
> sample weather dataset and Lorenzo Moretti's binaries under Mac OSX 10.3.5
> Problem #1. When I run r3.showdspf via g_gui(), it sends output to the tcltk
> output display window--as expected. However, it needs to send output to an
> xterm so that you can interact with it. I can script around this in
> tcltkgrass menus, but thought I would mention it.
> Problem #2. Potentially more serious. When I run r3.showdspf from the
> command line
>>>r3showdspf grid3=CloudLCP.992172300 dspf=test
> I get the desired prompt. But when I enter any of the normal r3.showdspf
> commands (e.g., +, -, d, ?) I get a "Broken pipe" error.
> I also get errors when I try to run r3.mkdspf. This generates many errors.
> For example....
> GRASS 5.7.cvs:~ > r3.mkdspf grid3=CloudLCP.992172300 dspf=cloudtest2 tnum=7
> Region from getWindow: 80 100 21
> ** cloudtest2 exists. ok to overwrite? (y/n) [n] y
> rows=80 cols=100 depths=21
> threshold values: 0.000000 0.183333 0.366667 0.550000 0.733333 0.916667
> 1.100000
> No. of thresholds: 8
> DSPF DIMS: 80 100 21
> Writing cloudtest2 from CloudLCP.992172300...display file completed:ERROR:
> G_fpc
> ompress_readXdrNums: read error
> ERROR: G3d_readTileCompressed: error in G_fpcompress_readXdrNums
> ERROR: G3d_readTile: error in G3d_readTileCompressed
> ERROR: cacheRead_readFun: error in G3d_readTile
> ERROR: G3d_cache_elt_ptr: error in c->eltLoadFun
> ERROR: G3d_getTilePtr: error in G3d_cache_elt_ptr
> FATAL ERROR: G3d_getFloatRegion: error in G3d_getTilePtr
> Any thoughts anyone?
> ____________________
> C. Michael Barton, Professor
> School of Human Diversity and Social Change
> PO Box 872402
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
