[GRASS5] Install Grass AMD Atlhon
Markus Neteler neteler at itc.it
Fri Aug 27 02:03:59 EDT 2004
On Wed, Aug 25, 2004 at 06:07:41PM -0500, aruizro at unal.edu.co wrote:
> my processor is athlon, I want to install grass but I cannot,
Please explain a bit more detailed.
> looks for in the Web an instruction that that says I must do it with CFLAGS, but does not do it, since I can do it.
Have a look at the INSTALL file in the source code.
It should explain the procedure.
Markus
