[GRASS5] D.vect.graph problem
Michael Barton michael.barton at asu.edu
Tue Aug 31 01:40:15 EDT 2004
I want to re-report a problem with d.vect.graph.
I have a point file in GRASS 5.7 (binaries from 22-07-2004 on Mac OSX
10.3.5). It displays fine in a UTM location.
If run d.vect.graph and I select a bar graph, all works fine.
If I select a pie chart, my computer slows to a crawl--all processes, not
just GRASS. Once I managed to get some of the pie graphs, including a partly
drawn graph before the computer dropped to low gear. I checked processes on
this once and GRASS was eating up nearly all the processing power and
available memory. I literally have to do a hard restart on the computer to
get control of it again.
I did NOT set a pie chart size column (it says optional). I left the rest at
the default or the settings that worked fine for bar graphs.
Any thoughts? Thanks.
Michael
____________________
C. Michael Barton, Professor
School of Human Diversity and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
