[GRASS5] [bug #2819] (grass) g.copy info message
Markus Neteler neteler at itc.it
Thu Dec 9 10:02:25 EST 2004
On Thu, Dec 09, 2004 at 12:15:50AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2819
> $ g.copy -o vect=largeCat,largeHouseNumbers
> COPY [largeCat at jidanni] to [largeHouseNumbers]
> Looks bad. Say
> COPY [largeCat at jidanni] to [largeHouseNumbers at jidanni]
> or
> COPY [largeCat] to [largeHouseNumbers]
Not sure if we want to change that. In GRASS you can only
copy to the current mapset.
However, I have extended the message to
g.copy vect=roads,test
COPY [roads at PERMANENT] to current mapset as [test]
Markus
