[GRASS5] [bug #2836] (grass) setting freetype fonttype permanently
Request Tracker grass-bugs at intevation.de
Fri Dec 10 17:11:00 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2836
Is show.fonts.sh still to be mentioned?
$ grep -c show display/d.font/description.html
2
Also d.font.freetype should say what file can set the font so he
doesn't have to put the whole path each time. Note e.g.,
/usr/lib/grass57/etc/freetypecap isn't writable by the user. Also
there is no user usable instructions there.
Also not all d.font.freetype's defaults might be listed with d.font.freetype help.
Also what good is writing text if one can't place it on a background...
to block what is underneath, like d.barscale can.
--- Headers Follow ---
>From jidanni at jidanni.org  Fri Dec 10 23:11:00 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 40E7B102C0B
	for <grass-bugs at lists.intevation.de>; Fri, 10 Dec 2004 23:11:00 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 0C01336DE2
	for <grass-bugs at lists.intevation.de>; Fri, 10 Dec 2004 23:10:59 +0100 (CET)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id 5837E36CE0
	for <grass-bugs at intevation.de>; Fri, 10 Dec 2004 23:10:59 +0100 (CET)
Received: from u69-109.u203-187.giga.net.tw ([203.187.69.109]:33188 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
	id 1CcsyO-000Fkk-5J by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Sat, 11 Dec 2004 03:40:57 +0530
To: grass-bugs at intevation.de
Subject: setting freetype fonttype permanently
Date: Fri, 10 Dec 2004 11:40:36 +0800
Message-ID: <87d5xi6csr.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.2 tagged_above=-999.0 required=3.0 tests=BAYES_00,
	DATE_IN_PAST_12_24
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
