[GRASS5] [bug #2835] (grass) v.net.path may just be a special case of v.net.salesman
Radim Blazek blazek at itc.it
Sat Dec 11 03:50:03 EST 2004
Request Tracker wrote:
> Also to v.net.path add: "To avoid v.path taking shortcuts over that
> unpaved trail, use three points and v.net.salesman." (If indeed the
> case.)
The correct way to avoid shortcuts is to assign attributes to arcs and
use costs from attribute table.
Radim
