[GRASS5] 4 more questions about d.vect for improving GIS Manager
Moritz Lennert mlennert at club.worldonline.be
Mon Dec 13 06:03:11 EST 2004
On Mon, December 13, 2004 5:39, Michael Barton said:
> As I thought I understood it, the print width setting only works with
> ps.map. But perhaps it is called if you use the print dialog in the GIS
> Manager? I guess the question is does this setting actually do anything from
> within the GIS Manager or is it something that people will only be able to
> use via ps.map?
As far as I understand the GIS Manager print dialog calls ps.map.
> Finally, an option that is NOT in the GIS Manager vector panel is the -c
> flag. This fills areas with random colors based on the cat field. I thought
> I'd add this if there is interest.
I've never really had any need for random coloring. However, if it would be
possible to substitute this by a colour palette (i.e. red to green, or
greyscale, etc) then it would be very interesting.
Moritz
