[GRASS5] [bug #2864] (grass) v.in.ogr fails many times
Wed Dec 22 06:59:41 EST 2004
> > Cannot open dbf database
> the database (directory) probably does not exist.
can the library function create $MAPSET/dbf/ automatically if it is
needed? Much like any other directory under $MAPSET/. I've been meaning
to add similar test+mkdir+db.connect code to v.in.garmin, but it would
be nice if this was done automatically if it doesn't exist.
or does this introduce other problems, e.g. if other db's are used?
Hamish
__________________________________
Do you Yahoo!?
Send holiday email and support a worthy cause. Do good.
http://celebrity.mail.yahoo.com
