[GRASS5] tcltk to default
John Gillette JGillette at rfmd.com
Wed Feb 4 12:34:46 EST 2004
Grass 5.3 snapshot 2004 01 17
Redhat 7.3 with updates
I can't out any way to have default graphics be tcltk except to
manually edit the .grassrc5 file.  It used to default to this after
first usage, I believe.
Is there a utility or command to set this in Grass?
Perhaps this should appear on the tcltk menu under or near
"Config"?
John
