[GRASS5] dig_plus file - How does it work?
John Gillette JGillette at rfmd.com
Tue Feb 10 17:23:43 EST 2004
You are going to have to look in the code.  Start with
<grass source>/src/include/vect/dig_structs.h
which gives the definitions of all the structures used to store topology
information.
Then start looking through some vector programs to see how topology
is used.  I have enclosed a simple program I worked on with another user
to give an area adjacency list.  It shows how to use the structures
to get area information.  I started this program
by looking at v.rm.dangles.
I never looked at the file structure because I didn't care.  I assume
that the contents of all the structures are written to the dig_plus file.
Note that this is 5.03 (or 5.3) information.  For 5.7 the vector
format has changed, although I would guess that a lot of information
is at least similar.
I hope that helps.  I wish it was documented as it is fundamental to
how vectors work.
John
Type: application/octet-stream
Desc: main.c
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040210/85248c04/main.obj
Desc: Gmakefile
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040210/85248c04/Gmakefile.obj
