[GRASS5] fix for problem opening monitor windows from the TclTk menu in WinGRASS
Scott Mitchell smitch at mac.com
Thu Feb 12 12:19:36 EST 2004
Looks like Moritz committed the change earlier today, it works fine for
me on both Intel/Linux(RedHat8) and Mac OS X 10.3.
On 11-Feb-04, at 13:47, Michael Barton wrote:
> Currently, if you try to open a monitor window in WinGRASS using the
> TclTk menus, it will flash open and close. It can eventually cause
> problems making it impossible to open monitor windows and sometimes to
> even open tcltkgrass. The current workaround is to always open
> monitors from the command line, using d.mon, prior to using them for
> displaying maps (including using the display manager, d.dm).
> Glynn Clements suggested a fix for this (see below). I've tested it on
> a Windows computer using Windows XP (and GRASS 5.0.3) and it does the
> trick. I've also tested it on my Mac (with GRASS 5.3) and it seems to
> cause no harm. I don't have access to Linnux or other Unix systems to
> test this, but I suspect it should be OK.
> The fix is a slight modification of a line in the
> $GISBASE/tcltkgrass/main/gui.tcl file. As Glynn suggested below,
> change the line
>> exec xterm -geometry 40x5 -e d.mon start=$monitor
> to
>>     exec d.mon start=$monitor &
> Could this be submitted to the CVS? Thanks
> Michael Barton
> Begin forwarded message:
>> Glynn Clements wrote:
>>>> 2. Can GRASS 5.3 open monitors via the tcltk menu or is it still
>>>> necessary to do this from the command line using d.mon?
>>> I didn't try that; I'll check later.
>> I've checked that; it still doesn't work.
>> The problem appears to be this in start_monitor, in gui.tcl:
>> The xterm terminates as soon as d.mon completes, which seems to end up
>> killing the monitor (this may be due to a difference in the way that
>> Cygwin handles terminals, or due to the use of the Win32 spawn()
>> function rather than Cygwin's fork+exec).
>> A possible fix is to change the above line not to use an xterm, i.e.
>> You will still need to select the monitor separately.
> ______________________________
> Michael Barton, Professor & Curator
> Department of Anthropology
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
Scott W. Mitchell		Scott_Mitchell at carleton.ca
Department of Geography and Environmental Studies
Carleton University, B349 Loeb Building (Office A209)
1125 Colonel By Drive, Ottawa, ON Canada K1S 5B6
+1-613-520-2600 ext 2695 Fax: 1-613-520-4301
