[GRASS5] grass5.0/5.3 - tcltkgrass: command line in the module windows is not copyable
Tue Feb 17 19:37:05 EST 2004
> > A question that came up on the French speaking list: In the module
> > windows opened by tcltkgrass, the command line that the chosen opens
> > create is displayed in the last text field of the window. Before,
> > one could copy this text field (and thus include the command in a
> > script, or simply learn how to use the command line). Now, this
> > field is not copyable anymore (at least under Debian
> > testing/unstable with XFCE and under Mandrake 9.2). Anyone know why
> I've seen the same thing with Debian/testing, versions of GRASS from
> 5.0.2 through 5.3. (NVIZ crashes, so I figure both were compiled with
> tcl8.4)
> On a Redhat 7.3 system, it works ok, 5.0.3preX & GRASS 5.3 from last month.
> I'll try compiling 5.3 with Tcl/Tk 8.3 on Debian and see if that works ...
Nope, GRASS 5.3 compiled with Tcl/Tk 8.3 on Debian/testing doesn't let
you select the command text.
Hamish
