[GRASS5] [bug #2326] (grass) Missing row and column when importing raster map with r.in.gdal
Morten Hulden morten at untamo.net
Fri Feb 20 18:23:56 EST 2004
I'm not sure, but rather than blaming r.in.gdal I think the original data
is ill-formatted.
(e - w) / ew-res and (n - s) / ns-res should be even numbers, but
(416060.318 - 131904.829) / 27.27543571 = 10417.999991686
(4561132.088 - 4317044.214) / 27.27543571 = 8948.9999938117
So, looks like r.in.gdal, rather than rounding up to 10418 and 8949, or
changing the resolution, trims half of the failing last row/column off
each side of the map.
Don't know if r.in.gdal in newer grass versions still does that, but I
would not consider it a bug. I think it would be more of a bug to round
cell number upwards, even if values here are rather close, since
resolution is given with 8 significant decimals.
rgds
Morten Hulden
On Wed, 18 Feb 2004, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2326
> Subject: Missing row and column when importing raster map with r.in.gdal
> Platform: other
> grass obtained from: Other (CDROM etc)
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.0.2 (April 2003)
> I tried to import a raster grid with r.in.gdal, and apparently, a row and a column is missing in the
> imported raster map (see below).
> # Files and directories:
> The files are located in the directory codem1nw:
> dblbnd.adf
> hdr.adf
> log
> prj.adf
> sta.adf
> w001001.adf
> w001001x.adf
> # w001001.adf (around 360 MB) contains the main data.
> # Info from codem1nw/prj.adf (maybe not necessary):
> Projection    UTM
> Zone          13
> Datum         NAD27
> Zunits        NO
> Units         METERS
> Spheroid      CLARKE1866
> Xshift        0.0000000000
> Yshift        0.0000000000
> Parameters
> # My default region:
> GRASS 5.0.2 > g.region -pd
> projection: 1 (UTM)
> zone:       13
> datum:      nad27
> ellipsoid:  clark66
> north:      4480020
> south:      4380000
> west:       235000
> east:       340000
> nsres:      30
> ewres:      30
> rows:       3334
> cols:       3500
> # gdalinfo:
> GRASS 5.0.2 > gdalinfo --version
> GDAL 1.1.9.0, released 2003/06/27
> # Libraries:
> ls -la /usr/local/lib:
> -rwxr-xr-x    1 christof  admin   3902472 23 Jan 09:33 libgdal.1.1.9.dylib
> -rwxr-xr-x    1 christof  admin   1363420  1 Jun  2001 libgdal.1.1.dylib
> # Import of raster map:
> r.in.gdal -o in=codem1nw out=codem1nw.r
> r.support -r codem1nw.r
> # There were no error messages during the import.
> # Info from gdalinfo:
> GRASS 5.0.2 > gdalinfo codem1nw
> Driver: AIG/Arc/Info Binary Grid
> Size is 10418, 8949
> Coordinate System is:
> PROJCS["UTM Zone 13, Northern Hemisphere",
>     GEOGCS["NAD27",
>         DATUM["North_American_Datum_1927",
>             SPHEROID["Clarke 1866",6378206.4,294.978698213898,
>                 AUTHORITY["EPSG","7008"]],
>             TOWGS84[-3,142,183,0,0,0,0],
>             AUTHORITY["EPSG","6267"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.0174532925199433,
>             AUTHORITY["EPSG","9108"]],
>         AXIS["Lat",NORTH],
>         AXIS["Long",EAST],
>         AUTHORITY["EPSG","4267"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",-105],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["METERS",1]]
> Origin = (131904.828978,4561132.087882)
> Pixel Size = (27.27543571,-27.27543571)
> Corner Coordinates:
> Upper Left  (  131904.829, 4561132.088)
> Lower Left  (  131904.829, 4317044.214)
> Upper Right (  416060.318, 4561132.088)
> Lower Right (  416060.318, 4317044.214)
> Center      (  273982.574, 4439088.151)
> Band 1 Block=256x4 Type=Float32, ColorInterp=Undefined
>   Min=1280.949 Max=4412.362
>   NoData Value=-3.40282e+38
> # Note the size (10418, 8949)
> # Info from the imported raster map:
> GRASS 5.0.2 > r.info codem1nw.r
>  | Layer:    codem1nw.r                     Date: Tue Feb 17 19:20:36 2004    |
>  | Mapset:   data1                          Login of Creator: christof        |
>  | Location: fire_flattops                                                    |
>  | DataBase: /Volumes/FatBoy2/Users/christof/Work/Postdoc/Grass_data          |
>  | Title:     ( codem1nw.r )                                                  |
>  |   Type of Map:  raster              Number of Categories: 4412             |
>  |   Data Type:    FCELL                                                      |
>  |   Rows:         8948                                                       |
>  |   Columns:      10417                                                      |
>  |   Total Cells:  93211316                                                   |
>  |        Projection: UTM (zone 13)                                           |
>  |            N: 4561145.72559973    S: 4317085.1268369   Res: 27.27543571    |
>  |            E: 416019.40508569    W: 131891.19125998   Res: 27.27543571     |
>  |   Range of data:    min =  0.000000 max = 4412.000000                      |
>  |   Data Source:                                                             |
>  |   Data Description:                                                        |
>  |    generated by r.in.gdal                                                  |
> # Note the size (10417, 8948)
> Using r.in.gdal -e ... or r.in.gdal ... location=newlocation did not change anything.
> This bug was submitted by Christof Bigler (Boulder, Colorado). If you need more information send
> me an e-mail.
> See also:
> http://www.ecosconsult.com.br/grass-list/arq/11524.html
> http://www.ecosconsult.com.br/grass-list/arq/11539.html
> http://www.ecosconsult.com.br/grass-list/arq/11556.html
> Thanks,
> Christof
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
