[GRASS5] [bug #2332] (grass) Missing row and column when importing raster map with r.in.gdal
Request Tracker grass-bugs at intevation.de
Mon Feb 23 10:11:44 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2332
Subject: Missing row and column when importing raster map with r.in.gdal
[Re-entered bug #2326 to hide email address as requested by user.]
Platform: other
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.2 (April 2003)
I tried to import a raster grid with r.in.gdal, and apparently, a row and a column
is missing in the
imported raster map (see below).
# Files and directories:
The files are located in the directory codem1nw:
dblbnd.adf
hdr.adf
log
prj.adf
sta.adf
w001001.adf
w001001x.adf
# w001001.adf (around 360 MB) contains the main data.
# Info from codem1nw/prj.adf (maybe not necessary):
Projection    UTM
Zone          13
Datum         NAD27
Zunits        NO
Units         METERS
Spheroid      CLARKE1866
Xshift        0.0000000000
Yshift        0.0000000000
Parameters
# My default region:
GRASS 5.0.2 > g.region -pd
projection: 1 (UTM)
zone:       13
datum:      nad27
ellipsoid:  clark66
north:      4480020
south:      4380000
west:       235000
east:       340000
nsres:      30
ewres:      30
rows:       3334
cols:       3500
# gdalinfo:
GRASS 5.0.2 > gdalinfo --version
GDAL 1.1.9.0, released 2003/06/27
# Libraries:
ls -la /usr/local/lib:
-rwxr-xr-x    1 christof  admin   3902472 23 Jan 09:33 libgdal.1.1.9.dylib
-rwxr-xr-x    1 christof  admin   1363420  1 Jun  2001 libgdal.1.1.dylib
# Import of raster map:
r.in.gdal -o in=codem1nw out=codem1nw.r
r.support -r codem1nw.r
# There were no error messages during the import.
# Info from gdalinfo:
GRASS 5.0.2 > gdalinfo codem1nw
Driver: AIG/Arc/Info Binary Grid
Size is 10418, 8949
Coordinate System is:
PROJCS["UTM Zone 13, Northern Hemisphere",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.978698213898,
                AUTHORITY["EPSG","7008"]],
            TOWGS84[-3,142,183,0,0,0,0],
            AUTHORITY["EPSG","6267"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9108"]],
        AXIS["Lat",NORTH],
        AXIS["Long",EAST],
        AUTHORITY["EPSG","4267"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-105],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["METERS",1]]
Origin = (131904.828978,4561132.087882)
Pixel Size = (27.27543571,-27.27543571)
Corner Coordinates:
Upper Left  (  131904.829, 4561132.088)
Lower Left  (  131904.829, 4317044.214)
Upper Right (  416060.318, 4561132.088)
Lower Right (  416060.318, 4317044.214)
Center      (  273982.574, 4439088.151)
Band 1 Block=256x4 Type=Float32, ColorInterp=Undefined
  Min=1280.949 Max=4412.362
  NoData Value=-3.40282e+38
# Note the size (10418, 8949)
# Info from the imported raster map:
GRASS 5.0.2 > r.info codem1nw.r
| Layer:    codem1nw.r                     Date: Tue Feb 17 19:20:36 2004
 | Mapset:   data1                          Login of Creator: christof
 | DataBase: /Volumes/FatBoy2/Users/christof/Work/Postdoc/Grass_data
 | Title:     ( codem1nw.r )
 |   Type of Map:  raster              Number of Categories: 4412
 |   Data Type:    FCELL
 |   Rows:         8948
 |   Columns:      10417
 |   Total Cells:  93211316
 |        Projection: UTM (zone 13)
 |            N: 4561145.72559973    S: 4317085.1268369   Res: 27.27543571
 |            E: 416019.40508569    W: 131891.19125998   Res: 27.27543571
 |   Range of data:    min =  0.000000 max = 4412.000000
 |   Data Source:
 |   Data Description:
 |    generated by r.in.gdal
# Note the size (10417, 8948)
Using r.in.gdal -e ... or r.in.gdal ... location=newlocation did not change
anything.
This bug was submitted by Christof Bigler (Boulder, Colorado). If you need more
information send
me an e-mail.
See also:
http://www.ecosconsult.com.br/grass-list/arq/11524.html
http://www.ecosconsult.com.br/grass-list/arq/11539.html
http://www.ecosconsult.com.br/grass-list/arq/11556.html
Thanks,
Christof
-------------------------------------------- Managed by Request Tracker
