[GRASS5] GRASS -> SF
Markus Neteler neteler at itc.it
Fri Feb 27 08:08:47 EST 2004
On Mon, Feb 23, 2004 at 07:31:34PM +0100, Morten Hulden wrote:
> On Sat, 21 Feb 2004, Morten Hulden wrote:
> > So, for me it would be very useful if I could interface the vector data in
> > Postgis from both Mapserver and Grass. I use Grass alot for raster map
> > generating and v.digitizing, but Grass is becoming a little 'isolated' now
> > from the vector storage. Maybe there is something in 5.7 that I don't know
> > about, but I haven't been able to get it to compile yet :-(
> Only yesterday I managed to compile 5.7 so I got a chance to test Postgis
> connectivity. (--with-nls causes errors in lib/raster/io.c, PACKAGE not
> defined)
The --with-nls Makefile bugs are fixed now (otherwise, please report).
> Vectors and attributes in Postgis/Postgres works fine, but areas are very,
> very slow to render.
Radim has updated two days ago 'd.vect' to render only areas in the
current region. Should be faster now (up to 3 times for me).
Please try again.
Markus
