[GRASS5] v.select attributes problem in 5.7
Christopher Fonnesbeck chris at fonnesbeck.org
Thu Jan 8 09:09:29 EST 2004
On Jan 8, 2004, at 4:34 AM, Radim Blazek wrote:
> On Wednesday 07 January 2004 21:57, Christopher Fonnesbeck wrote:
>> When running v.select on a vector coverage with attributes stored in a
>> relational database (MySQL), the new coverage of selected polygons is
>> associated with a new table that has as many entries as the original
>> table, even though the number of selected polygons is significantly
>> smaller. Is this a bug, or is there another way of getting an
>> attribute
>> table that contains only the attributes for the selected polygons?
>> Running 5.7 on OSX 10.3
> More or less bug, I did not have time to write db_copy_table_where()
> so db_copy_table is used and all records are written to output.
Can I then use v.extract to get the proper attribute table?
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
