[GRASS5] r.in.gdal
Bernhard Reiter bernhard at intevation.de
Mon Jan 26 11:55:36 EST 2004
On Mon, Jan 26, 2004 at 10:10:41AM -0600, Tom Parker wrote:
> I'm trying to resolve the r.in.gdal segmentation fault mentioned several
> times on the mailing list over the past year. The problem shows itself no
> matter what type of raster file I try and import.
> My sytem is redhat 9 with gdal/proj/grass all built from CVS.
> After installing and/or building and installing several versions of both
> grass and gdal as binaries or built from source the problem isn't fixed. If
> there is a simple fix I'd love to know it or I'd be happy to try and help
> fix the problem.
Can you build with debugging support and try
to see what the traceback says?
Check: http://grass.itc.it/grassdevel.html
for links to the "debugging" hints
Are there any versions you didn't build yourself?
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040126/7897cdf7/attachment.bin
