[GRASS5] [bug #2543] (grass) patches to build on openbsd without tcl/tk
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Jul 18 10:40:14 EDT 2004
On Sun, 18 Jul 2004, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2543
> Subject: patches to build on openbsd without tcl/tk
> Platform: other
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.7.0
> My platform is: OpenBSD/3.4 i386
> configure args were:
> --with-gdal=no
> --with-tcltk=no
> --with-postgres=no
> --with-odbc=no
> --with-motif=no
> --with-opengl=no
> + the path options for (proj png jpeg tiff).
> 1. because make is BSD make here, and GNU make is installed as gmake, i had to make these changes:
> --- Makefile.orig       Sun Jul 18 19:22:28 2004
> +++ Makefile    Sun Jul 18 19:22:38 2004
> @@ -29,7 +29,7 @@
> # Shell commands
> MAKE_DIR_CMD=          mkdir -p -m 755
> -MAKE=                  make
> +#MAKE=                 make
> INSTALL=               cp
Already done in latest CVS (several weeks ago)
> --- include/Make/Platform.make.in.orig  Sun Jul 18 19:15:29 2004
> +++ include/Make/Platform.make.in       Sun Jul 18 19:15:40 2004
> @@ -27,7 +27,7 @@
> LEX                 = @LEX@
> YACC                = @YACC@
> PERL                = @PERL@
> -MAKE                = make
> +#MAKE                = make
> AR                  = @AR@
> RANLIB              = @RANLIB@
> MKDIR               = mkdir -p
This was already done also
> --- vector/v.clean/Makefile.orig        Sun Jul 18 23:16:08 2004
> +++ vector/v.clean/Makefile     Sun Jul 18 23:16:21 2004
> @@ -13,4 +13,4 @@
> default: cmd ctest
> ctest:
> -       cd test; make
> +       cd test && $(MAKE)
This one I have done just now. The test directory is always going to be
there so I'm not sure if && rather than ; is necessary: to err on the side
of caution I left it as it was and just changed make to $(MAKE)
> 2. also there were some assumptions about OGR which caused link errors
Will leave those to Radim to decide
> 3. i couldn't figure out how the shared library stuff was figured out. whatever configure detected was just totally broken. so in the end i modified the Shlib.make to use gcc's -shared argument. i don't know how to fix this properly (it is a hard problem. maybe use libtool?)
The aim is not to have to use libtool. The shared library compile flag
detection originally came from the Tcl source tree (and had some bugs);
last week it was updated to a more recent version so hopefully the problems
you had will be solved in the latest CVS. Please try.
Paul K
