[GRASS5] [bug #2545] (grass) vect32 fails to build
Request Tracker grass-bugs at intevation.de
Sun Jul 18 15:07:47 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2545
Subject: vect32 fails to build
Platform: other
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
Looks like some changes in the makefiles in libes/vect32 are causing problems.  I get this error:
GISGEN: src/libes/vect32 - Sat Jul 17 21:49:19 CDT 2004
/Users/williamk/Documents/src/unix/GRASS/grass53_exp_2004_07_17/src/libes/vect32
  mkdir OBJ.powerpc-apple-darwin7.4.0
  make -f OBJ.powerpc-apple-darwin7.4.0/make.rules
mkdir -p /Users/williamk/Documents/src/unix/GRASS/grass53_exp_2004_07_17/src/libes/vect32/
Vlib
diglib
make[1]: *** No rule to make target `Vlib/OBJ.powerpc-apple-darwin7.4.0/close.o', needed by `/
Users/williamk/Documents/src/unix/GRASS/grass53_exp_2004_07_17/src/libes/LIB.powerpc-
apple-darwin7.4.0/libvect_combined.a'.  Stop.
GISGEN failure at STEP: src/libes/vect32
and then a bunch of other vector stuff fails later on.  I guess the snapshot caught the CVS tree in a
not-quite-working state.
-------------------------------------------- Managed by Request Tracker
