[GRASS5] Re: GRASS 5.7.0 beta1
Radim Blazek blazek at itc.it
Thu Jun 3 07:00:24 EDT 2004
On Thursday 03 June 2004 04:01, Hamish wrote:
> > Now the display manager pops-up and a "task bar" -- looks great, much
> > more modules included, looks pretty sophisticated!
> Nice, isn't it.
> > BTW when I do v.digit -> polygon and click right mouse button the
> > polygon should be closed, shouldn't it? In the display it is still
> > open.
> Hm. That's not working correctly for me either.
> Snapping only seems to work with previously established nodes; you can
> change the thresholds in the settings menu, the default is 10 screen
> pixels. So currently you need to use the "add vertex" tool to close the
> area? Or move well away with the "move vertex" tool and then move it
> back to get the area to close properly. shrug.
Yes.
Radim
