[GRASS5] GRASS 5.7.0 beta1
Glynn Clements glynn.clements at virgin.net
Fri Jun 4 09:24:59 EDT 2004
Radim Blazek wrote:
> On Friday 04 June 2004 00:29, Glynn Clements wrote:
> > And, environment issues aside, you can't make the shell close the
> > history file and start writing a new one. You just have to accept the
> > fact that the history will be stored in the starting mapset.
> In bash it is possible to do
> export  HISTFILE=myhist1
> history -w
> history -r myhist2
OK; but shouldn't that be:
	history -w
	HISTFILE=myhist2
	history -r
Presumably, changing HISTFILE will determine where the history is
written upon exit?
> similarly in tcsh it should be possible
> history -S myhist1
> history -L myhist2
> but it must be in a script without #!/bin/, is it a problem?
Yes; it's the same issue as environment variables.
You would have to have g.mapset (or whatever) emit shell commands,
then use e.g.:
	eval `g.mapset`
Or make g.mapset a script such that you could run:
	source g.mapset
Or make g.mapset spawn a new shell (similar to the way that the newgrp
program works).
Glynn Clements <glynn.clements at virgin.net>
