[GRASS5] Re: [bug #2488] (grass) Transaction (glynn.clements@virgin.net)
Glynn Clements glynn.clements at virgin.net
Thu Jun 17 06:40:37 EDT 2004
Michael Barton wrote:
> Thanks much for responding so quickly. Here is what happens. If you
> just want to echo a string, it works OK. If you want to use the string
> as an argument to an option, it won't work. For example, look at
> d.vect. In the SQL box, you can put <field>=value and it works fine (no
> spaces). But you cannot put <field>=value and <field2>=value2. This
> generates an error that <field> value <field2> and value2 are illegal
> values--i.e., it treats each part of the argument as a separate entry.
> However you can do this on the command line with sql='<field>=value and
> <field2>=value2'.
> I ran into this trying to do a script for gdalwarp. I just hit it again
> doing a script to make v.in.ascii read in a points file from a GUI
> interface. To specify column definitions you need to do
> v.in.ascii .... columns='xcoord double,ycoord double,name varchar(10)'
> or something along that line.
> This works from the command line. But in a g.parser GUI dialog,
> anything you put into am entry box for this variable gets parsed as a
> series of illegal entries rather than a single string argument. I've
> tried to quote it in the script, manually when I enter it, and other
> ways and have the same results.
First, are we talking about g.parser or G_parser()?
If the problem is with the Tcl/Tk dialogs, that's probably a bug in
G_gui(). ISTR that tcltkgrass suffers from the same problem.
Glynn Clements <glynn.clements at virgin.net>
