[GRASS5] Proposed freetype/configure patches
    Markus Neteler
    neteler at itc.it
    Wed Jun 23 06:31:29 EDT 2004
On Tue, Jun 22, 2004 at 10:18:21AM +0200, Buchan Milne wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Glynn Clements wrote:
> | Markus Neteler wrote:
> |>>>>From a Mandrake developer I received the attached
> |>>>patches (5.0.3/5.3, 5.7).
> |>>>Can I apply them?
> |>>>-LOC_CHECK_INCLUDES(freetype/freetype.h,FreeType,$FTINC)
> |>>>+LOC_CHECK_INCLUDES(ft2build.h,FreeType,$FTINC)
> |>>We changed from checking ft2build.h in 5.0.0 to freetype/freetype.h in
> |>>5.0.1, and we presumably did so for a reason.
> |>>Unless someone beats me to it, I'll try to find the commit message and
> |>>any emails relating to the change.
> |>OK, here is the commit log:
> |> http://grass.itc.it/pipermail/grass-commit/2002-September/006605.html
> |>So it should be somewhere here:
> |> http://grass.itc.it/pipermail/grass5/2002-September/author.html#start
> | Nope; it turns out to have been a private email (from you):
> |>From: Markus Neteler <neteler at itc.it>
> |>To: Glynn Clements <glynn.clements at virgin.net>
> |>Subject: Question on configure
> |>Date: Tue, 24 Sep 2002 15:01:12 +0200
> |>Message-ID: <20020924150112.G25861 at itc.it>
> |>to get configure accepting the freetype lib (Redhat 7.1)
> |>I had to change:
> |>cvs diff configure
> |>Index: configure
> |>RCS file: /grassrepository/grass/configure,v
> |>retrieving revision 1.117
> |>diff -r1.117 configure
> |>10489c10489
> |>< for ac_hdr in ft2build.h
> |>>for ac_hdr in ./freetype/config/ftbuild.h
> |>as ft2build.h does not exist on Redhat 7.1:
> |>locate /freetype/config/ftbuild.h
> |>/usr/include/freetype2/freetype/config/ftbuild.h
> |>May I ask you to modify the configure[.in] if possible?
> | Currently, d.text.freetype/main.c does:
> | 	#include <freetype/freetype.h>
> | So, that's what configure should be checking for. If the source code
> | was changed to include ft2build.h (and use the macros for including
> | the other headers), then changing the configure checks would make
> | sense.
> I sent Markus two patches, one for grass-5.{0,3}, which just change the
> configure.in, the one for grass-5.7 added an #include ft2build.h (but it
> was incomplete, it needs to use the macro to get the freetype header).
> The problem is that with freetype-2.1.8 and later, freetype.h now has:
> #ifndef FT_FREETYPE_H
> #error "`ft2build.h' hasn't been included yet!"
> #error "Please always use macros to include FreeType header files."
> #error "Example:"
> #error "  #include <ft2build.h>"
> #error "  #include FT_FREETYPE_H"
> #endif
> So, configure in grass-5.{0,3} fails, even though nothing seems to
> include the header, and compilation fails (if configure succeeded) in
> d.text.freetype.
I have applied the patches to 5.3-CVS and 5.7-CVS.
 Markus
