[GRASS5] Re: [Gdal-dev] ERDAS/IMG driver error for NULL values
Radim Blazek blazek at itc.it
Wed Jun 30 12:34:27 EDT 2004
On Wednesday 30 June 2004 17:11, Paul Kelly wrote:
> > grassdataset.cpp3
> > configure.in.patch2
> >> I am using the new driver which contains the relevant code (I'm no
> >> expert). Somewhere this info get's lost. Or should the driver make
> >> use of the new GRASS 5.7 projection functions (such as GPJ_grass_to_wkt
> >> in grass57/lib/proj/convert.c )?
> Yes I see what you mean now, that Radim's new patches call
> GPJ_grass_to_wkt() and the co-ordinate system should be included
> automatically. I'll look at it if I have some time; mightn't be for a few
> days though.
GPJ_grass_to_wkt is disabled in grassdataset.cpp3 because of circular references,
projection is not set.
Radim
