[GRASS5] can't get 5.7 to get past ./configure
Jeff D. Hamann jeff.hamann at forestinformatics.com
Sun Mar 7 03:52:33 EST 2004
I've tried to compile the 5.7 (or 5.1 or whatever the name is this week)
and can't seem to get past the ./configure. I've run ./configure with the
following settings...
./configure --with-includes=/ur/local/include \
            --with-libs=/usr/local/lib \
            --without-postgres \
            --without-tcltk \
            --without-fftw \
            --with-proj \
            --with-grass50=/usr/home/hamannj/grass
and get the following results:
GRASS is now configured for:  i386-unknown-freebsd4.9
 Source directory:            /usr/home/hamannj/grass51
 Build directory:             /usr/home/hamannj/grass51
 Installation directory:      /usr/local/grass57
 Startup script in directory: ${exec_prefix}/bin
 C compiler:                  gcc -g -O2  -pthread -pthread
 C++ compiler:
 FORTRAN compiler:            f77
 Building shared libraries:   yes
  NVIZ:                       no
  X11 support:                yes
  JPEG support:               yes
  TIFF support:               yes
  PNG support:                yes
  Tcl/Tk support:             no
  PostgreSQL support:         no
  MySQL support:              no
  OpenGL(R) support:          yes
  ODBC support:               yes
  FFTW support:               no
  BLAS support:               no
  LAPACK support:             no
  Motif support:              no
  FreeType support:           no
  GLw support:                no
  NLS support:                no
  Readline support:           no
  C++ support:                no
  openDWG support:            no
  GDAL support:               yes
  OGR support:                yes
when I attempt to run make, I get,
$ make
"./include/Make/Grass.make", line 235: Missing dependency operator
"./include/Make/Grass.make", line 308: Need an operator
"Makefile", line 51: Missing dependency operator
"Makefile", line 53: Need an operator
make: fatal errors encountered -- cannot continue
Is there something I'm doing incorrectly? I've performed a cvs checkout of
the grass51 code into a fresh directory such that my home dir looks
something like:
and have been successful in compiling and running grass5.3
Ideas?
Jeff.
Jeff D. Hamann
Forest Informatics, Inc.
PO Box 1421
Corvallis, Oregon 97339-1421
phone 541-754-1428
www.forestinformatics.com
