[GRASS5] Re: more on color rules
Helena hmitaso at unity.ncsu.edu
Thu May 13 10:19:52 EDT 2004
Michael,
if I understand your suggestions correctly, there should already be there
(at least in the command line version)
> Given this, it seems that there needs to be 2 options for reading in
> files: rules=[predefined rules, including the default GRASS set]
that is already there, through option color=
and you use either the predefined set of color tables or your own rules,
if you have the rules in a file you redirect that file to the command
as explained by Glynn in his previous email
and
> map=[for reading rules from another map];
that is there as an option rast=name
and one flag for interactive
> rule creation on the fly.
that is there through option color=rules
Helena
The flag would override the options (more
> convenient than having to make sure the options are blank in the GUI). I
> definitely like the idea of having the rules option somehow autogenerate
> a list in the GUI. For the CLI, the displayed options could be limited
> to the default GRASS set to keep it from getting too cluttered.
> Michael Barton
> ____________________
> C. Michael Barton, Professor
> School of Human Origins, Cultures, & Societies
> PO Box 872402
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> On May 11, 2004, at 2:01 AM, grass5-request at grass.itc.it wrote:
>>>>>> Also, it won't even get this far from the autogenerated GUI
>>>>>> because it conflicts with the type=[option] argument. There
>>>>>> needs to be a 'none' selection for the type option in the GUI
>>>>>> header.
>>>>> It needs to be a separate menu entry; exactly the same issue also
>>>>> applies to the rast= option.
>>>> What about a function which reports the names of the currently
>>>> existing files in $GISBASE/etc/colors/ ? A function which
>>>> returns the file names as comma separated list?
>>> The problem here is that the list could grow rather quickly now that
>>> it can be extended without having to write any code.
>> I don't see this as a big problem if the default install is limited to
>> a dozen or so default color scales (we shouldn't be drowning the users
>> with many like options IMO).
>> If someone wants to install 200 custom rules files, they get to deal
>> with the consequences... same as if they installed 200 TT fonts on their
>> computer.
>> Perhaps we should add a -l flag to list available rules? Then the
>> default help page/parser stays clean.
>> see 'g.mapsets -l'
>> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
