[GRASS5] Can't get d.vect to display my data from PostGRASS
Radim Blazek blazek at itc.it
Thu May 20 01:38:29 EDT 2004
On Wednesday 19 May 2004 23:42, you wrote:
> Since posting the last message, I executed a v.build on the map. Now
> all the ids are 0 (instead of 301) and I get a bus error from d.vect. I
> am not very familar with the GRASS code, but it appears that
> Line->offset is always 0 in V2_read_line_post():
>    Line = Map->plus.Line[line];
>    return Vect__Read_line_post (Map, line_p, line_c, Line->offset);
> Could this mean that the files in the GRASS database are not built
> properly? Or have i screwed something up somewhere?
> Craig
> On 19-May-04, at 1:09 PM, Funkmeister wrote:
> <snip>
> > Note the id=301.
PostGIS support was removed from GRASS 5.7.
http://grass.itc.it/pipermail/grassuser/2004-May/025539.html
Radim
