[GRASS5] Let's release 5.4 asap
Radim Blazek blazek at itc.it
Fri Oct 1 10:00:43 EDT 2004
On Friday 01 October 2004 15:25, Bernhard Reiter wrote:
> > > I can move files or directories around in CVS in principle.
> > > Just need a good list.
> > > (probably the right mv commands might be most instructive ;) )
> > > and then I need to schedule shutting down CVS
> > > and doing the change.
> > > (Depending on my time this might a few days, so giving me an ahead
> > > notice is appreceated.)
> > The list is here:
> > http://freegis.org/cgi-bin/viewcvs.cgi/grass51/tools/link.conf?rev=1.72&c
> >ontent-type=text/vnd.viewcvs-markup excluding *akefiles and subdirs,
> >   (see
> > http://freegis.org/cgi-bin/viewcvs.cgi/grass51/tools/link?rev=1.8&content
> >-type=text/vnd.viewcvs-markup ) it can still copy unused files, which is
> > not harm, I think.
> > Should be 'cp', not 'mv', I believe.
> Yes!
> I would appreciate if someone would make a fixed list of "cp"
> command lines that I only need to source with the ",v" extension,
> because that seems more transparent as a script.
> Especially must there be checking if there is a corresponding file already?
Yes.
> Do you want me to
> 	mv grass51 grass57
> ,too?
No.
> > Initial comment (probably a new comment appended at the end),
> > should tell in unique form, where it was taken from (grass5 tree).
> During a copy operation in the repository someone cannot put in CVS
> comments, they would be exactly the same as in the original file.
> Probably with cvs admin you can change something.
> Maybe basiing revision numbers starting with "2.x" ?
> When do you want this to happen?
> Next week?
> After 5.4 release?
Radim
