[GRASS5] CVS changes; when?
Bernhard Reiter bernhard at intevation.de
Sat Oct 2 11:00:24 EDT 2004
We have no schedule yet.
I cannot judge how complicated the current copying
or mix linking is and how many changes are going to be made
to the files. So the timing must be up for somebody else to decide.
On Fri, Oct 01, 2004 at 04:00:43PM +0200, Radim Blazek wrote:
> On Friday 01 October 2004 15:25, Bernhard Reiter wrote:
> > > > I can move files or directories around in CVS in principle.
> > > > Just need a good list.
> > > > (probably the right mv commands might be most instructive ;) )
> > > > and then I need to schedule shutting down CVS
> > > > and doing the change.
> > > > (Depending on my time this might a few days, so giving me an ahead
> > > > notice is appreceated.)
> > > The list is here:
> > > http://freegis.org/cgi-bin/viewcvs.cgi/grass51/tools/link.conf?rev=1.72&c
> > >ontent-type=text/vnd.viewcvs-markup excluding *akefiles and subdirs,
> > >   (see
> > > http://freegis.org/cgi-bin/viewcvs.cgi/grass51/tools/link?rev=1.8&content
> > >-type=text/vnd.viewcvs-markup ) it can still copy unused files, which is
> > > not harm, I think.
> > > Should be 'cp', not 'mv', I believe.
> > Yes!
> > I would appreciate if someone would make a fixed list of "cp"
> > command lines that I only need to source with the ",v" extension,
> > because that seems more transparent as a script.
> > Especially must there be checking if there is a corresponding file already?
> Yes.
> > Do you want me to
> > 	mv grass51 grass57
> > ,too?
> No.
> > > Initial comment (probably a new comment appended at the end),
> > > should tell in unique form, where it was taken from (grass5 tree).
> > During a copy operation in the repository someone cannot put in CVS
> > comments, they would be exactly the same as in the original file.
> > Probably with cvs admin you can change something.
> > Maybe basiing revision numbers starting with "2.x" ?
> > When do you want this to happen?
> > Next week?
> > After 5.4 release?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041002/c9cda445/attachment.bin
