[GRASS5] bugs
Bernhard Reiter bernhard at intevation.de
Fri Oct 8 07:00:08 EDT 2004
Hi Paolo,
thanks for noticing.
Paul and Scott resolved the mentioned bugs.
Help with the bug tracker is always welcome,
let me know if you want an account so you can directly help.
Bernhard
On Mon, Oct 04, 2004 at 02:43:38PM +0200, Paolo Cavallini wrote:
> I just checked the bugs page, and I discovered that several bugs marked as
> open are in fact solved/non existent (e.g. #2532, #2644).
> Could someone who has access to the bugtracker clean up the situation a bit?
> Thanks.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041008/d1465301/attachment.bin
