[GRASS5] Let's release 5.4 asap
Markus Neteler neteler at itc.it
Sun Oct 10 14:27:41 EDT 2004
On Fri, Oct 08, 2004 at 12:37:37PM +0200, Bernhard Reiter wrote:
> On Mon, Oct 04, 2004 at 10:47:31AM +0200, Markus Neteler wrote:
> > On Fri, Oct 01, 2004 at 01:32:03PM +0200, Bernhard Reiter wrote:
> > > got you wrong on that point then.
> > > Moving it into the old section is of course fine.
> > > (Though currently the links to the old section make
> > > you search a bit until you find it again... )
> > ... which is good to avoid that "normal" users grab the old
> > stuff (and then complain). If a software engineer wants to
> > study the development history of GRASS, they'll be able to
> > find it :-)
            ^^^^^- (hint)
> I tend to disagree, because this has a mental model
> or "normal" users that I do not share.
> A clear marking should be fine and adaquate for a good archive.
I can imagine many useful improvements for the web site.
... finally it needs someone to realize them.
Markus
