[GRASS5] r.mapcalc compile error on Solaris
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Oct 11 10:03:08 EDT 2004
On Mon, 11 Oct 2004, Glynn Clements wrote:
More comments on the other bits when I've time to look at them... (could
also have been a problem using Solaris lex with GNU bison)
>> gcc -I/home/pkelly/grass/gbld/src/raster/r.mapcalc3 -I/home/pkelly/grass/grass/src/raster/r.mapcalc3 -I/home/pkelly/grass/grass/src/include -I/home/pkelly/grass/gbld/src/include -O2     -fPIC   -c -o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/lex.yy.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/lex.yy.c
>> /home/pkelly/grass/gbld/src/raster/r.mapcalc3/lex.yy.c: In function `get_input_string':
>> /home/pkelly/grass/gbld/src/raster/r.mapcalc3/lex.yy.c:112: error: `YY_NULL' undeclared (first use in this function)
> This might be a flex extension; try adding:
> 	#ifndef YY_NULL
> 	#define YY_NULL 0
> 	#endif
> to the top of mapcalc.l (anywhere between the %{ and get_input_string()).
Yes that worked. Got a lot further. Next error:
make: Entering directory `/home/pkelly/grass/grass/src/raster/r.mapcalc3'
mkdir -p /home/pkelly/grass/gbld/src/raster/r.mapcalc3
make -f makefile
make[1]: Entering directory `/home/pkelly/grass/grass/src/raster/r.mapcalc3'
gcc -L/home/pkelly/grass/gbld/src/libes -s   -Wl,-R,/home/pkelly/grass/gbld/src/libes -o /home/pkelly/grass/gbld/dist.sparc-sun-solaris2.8/etc/bin/cmd/r.mapcalc /home/pkelly/grass/gbld/src/raster/r.mapcalc3/y.tab.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/lex.yy.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/evaluate.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/expression.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/function.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/check.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/main.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xabs.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xadd.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xand.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xatan.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xcos.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xdiv.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xdouble.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xeq.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xeval.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xexp.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xfloat.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xge.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xgraph.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xgt.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xif.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xint.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xisnull.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xle.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xlog.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xlt.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xmax.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xmedian.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xmin.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xmod.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xmode.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xmul.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xne.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xneg.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xnot.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xnull.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xor.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xpow.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xrand.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xround.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xrowcol.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xsin.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xsqrt.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xsub.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xtan.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/map.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xcoor.o /home/pkelly/grass/gbld/src/raster/r.mapcalc3/xres.o -lgrass_gis -lsocket  -lgrass_btree -lgrass_rowio    -lm  -lnsl    -lz
Undefined			first referenced
  symbol  			    in file
yyterminate                         /home/pkelly/grass/gbld/src/raster/r.mapcalc3/lex.yy.o
ld: fatal: Symbol referencing errors. No output written to /home/pkelly/grass/gbld/dist.sparc-sun-solaris2.8/etc/bin/cmd/r.mapcalc
collect2: ld returned 1 exit status
make[1]: *** [/home/pkelly/grass/gbld/dist.sparc-sun-solaris2.8/etc/bin/cmd/r.mapcalc] Error 1
make[1]: Leaving directory `/home/pkelly/grass/grass/src/raster/r.mapcalc3'
make: *** [dir] Error 2
make: Leaving directory `/home/pkelly/grass/grass/src/raster/r.mapcalc3'
