[GRASS5] Re: grass57 and 3D import
Mon Oct 11 21:57:45 EDT 2004
> > The motivation is that v.in.sites currently doesn't make a table
> Realy?
Nope.
I could have sworn last time I tried this it didn't work.
Oh well, never mind.
>> 1. How do I create a new column in a table within a dbf file? Is it
>> possible through GRASS? Or should I just use a seperate tool?
> echo "alter table xxx add column yyy double precision" | db.execute
I see that is already in the db.execute help page;
Is it possible to rename a column after it is created?
Should we have a DB howto page in addition to the existing SQL howto
help page?
Re. broken man page generation; I see that most of the database
commands are breaking the script (if that helps the debugging):
  http://grass.ibiblio.org/grass57/manuals/html57_user/database.html
Hamish
