[GRASS5] Re: [GRASSLIST:4542] Re: turnoff tcl/tk interface
Glynn Clements glynn.clements at virgin.net
Thu Oct 14 20:50:27 EDT 2004
Paul Kelly wrote:
> > mapset / location / etc...  but does nothing for commands that I might issue
> > afterwards (e.g.  r.in.gdal, r.colors, etc...) these interfaces still
> > pop-up...
> >   Can someone tell me what the magic incantation is to get all these gui's
> > to stop popping up?
> I take it you're using 5.7? Setting the environment variable GRASS_UI_TERM
> to anything should stop this. Note that the tcltkgrass menu entries won't
> work if you have this set, as they assume it isn't set.
tcltkgrass should explicitly unset this variable.
Glynn Clements <glynn.clements at virgin.net>
