[GRASS5] stdout and stderr
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Oct 17 09:04:05 EDT 2004
Hello developers
I was just wondering about the appropriateness of writing different types
of module output to stderr or stdout, as I notice there has been some
activity in 5.7 in this area recently. I am wondering if perhaps I have
been wrong about how this should be used before:
When writing new code and fixing bugs I have tended to ensure that only
output which is the actual result of a GIS processing operation that needs
to be displayed to the user (rather than written to a file in the GRASS
database) should be written to stdout. All other errors, warnings,
informative progress messages and copyright notices etc. are written to
stderr.
I'll use the example of re-directing output to a file to show why this
makes logical sense to me.
g.proj -wf proj4=+init=epsg:29900 > irishgrid.prj
The point of this command is to convert the projection description
described by '+init=epsg:29900' in PROJ.4 format into WKT format and store
it in a .prj file. The WKT output is printed to stdout and stdout
re-directed to a file, which accomplishes this nicely. But on running the
above command, it is determined that +init=epsg:29900 does not contain
enough information on datum parameters, so the user is prompted for more
information. These prompts are written to stderr, so the user can still
see them even though stdout is re-directed. The user can interactively
choose the datum paramters and then the final version of the WKT output is
written to the file. If the prompts also went to stdout then the user
wouldn't see them and the program would just hang waiting for input from
the user.
I suppose that for modules that only write output to another file in the
GIS database, having information messages printed to stdout wouldn't
result in mixing up, but still I was under the (possibly mistaken)
impression that writing to stderr ensured the messages would always appear
where the user could see them and act on them, regardless of where stdout
was appearing (e.g. in a future GUI perhaps the stdout would be placed in
a pretty 'results' window to be stored while stderr could be kept out of
the way).
Any thoughts?
Paul
