[GRASS5] [bug #2664] (grass) r.contour writes negative elevations to category
Radim Blazek blazek at itc.it
Tue Oct 19 12:51:04 EDT 2004
On Monday 18 October 2004 18:16, William K wrote:
> Cool.  But, slight problem - the cat values used in the vectors ranges
> from 1..n, while the cat values used in the table range from 0..n-1 (n
> being the number of unique levels from r.contour).  So all the contours
> get shifted up 1 level, and the upper contours have no db record.
Thanks. Fixed.
Radim
