[GRASS5] 5.7 - GIS manager - zoom and pan - change term to execute in d.m.tcl
Wed Oct 20 10:06:26 EDT 2004
[Debian/testing: Zoom, Pan, digit, and query buttons don't work in d.m]
> > > See if this fixes the problem. If so, I can easily make a generic
> > > change to all the buttons as they all use this format.
> > No, this doesn't make a difference for me...
> > When I try to launch 'xterm -e d.zoom' from the GRASS command line,
> > I have the same problem. When I launch xterm from the GRASS command
> > line I get an xterm, but when I enter d.zoom in there, I get:
> > d.zoom: error while loading shared libraries: libgrass_display.so:
> > cannot open shared object file: No such file or directory
> This usually occurs because xterm is setuid/setgid. For security
> reasons, the loader unsets certain environment variables (e.g.
> LD_LIBRARY_PATH) when running setuid/setgid programs.
> You need to add the full path for $GISBASE/lib to /etc/ld.so.conf then
> run ldconfig. This will allow the GRASS shared libraries to be found
> when LD_LIBRARY_PATH is unset.
[that fixes it but isn't a real solution]
mmmn..
$ ls -l `which xterm`
-rwxr-sr-x  1 root utmp 259896 Sep 29 00:10 /usr/bin/X11/xterm*
'adduser $USER utmp' doesn't help. didn't try as root.
from the command line:
xterm -e "ls $LD_LIBRARY_PATH/libgrass_gis* ; g.version ; read"
pops up a window with this output:
/usr/local/src/grass/grass57/dist.i686-pc-linux-gnu/lib/libgrass_gis.so
g.version: error while loading shared libraries: libgrass_gis.so: cannot open shared object file: No such file or directory
so $LD_LIBRARY_PATH survives, ???
$PATH must survive, otherwise it wouldn't have found the
$GISBASE/bin/g.version which called libgrass_gis.so ...
If it were ignoring $LD_LIBRARY_PATH I'd think it would ignore $PATH
as well?
anyone remember if there was a Debconf question about this lately?
some possible temporary fixes for display/d.m/d.m.tcl:
d.zoom      changing 'term' to 'run' seems to work (text->console)
d.zoom -p   changing 'term' to 'run' seems to work (text->console)
   'term' would need:  set cmd "d.zoom"; set args "-p"; term $cmd $args ??
query       ? don't know how to fix
r.digit:    changing 'term' to 'run' seems to work (text->console)
             comment out $sel with a # (or remove)
             [no base map needed; best to open g.mapsets like menu
              for vector / raster digitizing if nothing selected??]
Hamish
