[GRASS5] 5.7 - GIS manager - zoom and pan - change term to execute in d.m.tcl
Wed Oct 20 21:28:16 EDT 2004
> A better solution is to install a script to re-set LD_LIBRARY_PATH,
> e.g.:
> 	#!/bin/sh
> 	if [ -n "$LD_LIBRARY_PATH" ] ; then
> 		LD_LIBRARY_PATH=$GISBASE/lib:$LD_LIBRARY_PATH
> 	else
> 	fi
> 	export LD_LIBRARY_PATH
> 	prog="$1"
> 	shift
> 	exec "$prog" "$@"
> then change the "term" function to use it, e.g.:
> 	proc term {cmd args} {
> 	    eval exec -- xterm -e $env(GISBASE)/etc/run $cmd $args &
> The script would have to be dynamically generated to use the correct
> variable name, as is currently done for etc/Init.sh.
> > from the command line:
> > xterm -e "ls $LD_LIBRARY_PATH/libgrass_gis* ; g.version ; read"
> > pops up a window with this output:
> > /usr/local/src/grass/grass57/dist.i686-pc-linux-gnu/lib/libgrass_gis.so
> > g.version: error while loading shared libraries: libgrass_gis.so: cannot open shared object file: No such file or directory
> > so $LD_LIBRARY_PATH survives, ???
> No. The expansion is performed by the shell from which xterm is run.
aah, yes.
> You would need to use e.g.:
> 	xterm -e sh -c 'ls $LD_LIBRARY_PATH/libgrass_gis* ; g.version ; read'
> [Note: *single* quotes.]
That gives:
ls: /libgrass_gis*: No such file or directory
Other checks show that $PATH and $GISBASE both survive.
So implementing the above script should fix this.
Hamish
