[GRASS5] Re: [GRASSLIST:4606] Re: 5.4.0 Release Candidate on solaris 9
Gordon Keith gordon.keith at csiro.au
Fri Oct 22 00:14:59 EDT 2004
On Fri, 22 Oct 2004 15:05, Hamish wrote:
> > Any idea why it has chosen the Alternate build mechanism?
> 5.4 was changed to do this, as shared libraries should work on all
> (most) platforms now.
from INSTALL:
The intent of the install method is to have the following sequence
of commands work to install GRASS on any platform.
        ./configure
        make
        make install
from error:
configure: error: ***  Build directory should not be the same as source
directory for the alternate build mechanism. Create a separate build
directory and run again, e.g. mkdir ~/grass-build; cd ~/grass-build; /usr/
src/grass/configure ... (see mk/README)
Am I missing something, or is the build process a lot harder than it should
be?
(I'm looking at it as a pre-release for a stable version, not as a development
version, so I'm being fussier than normal)
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
42.7% of all statistics are made up.
